Multiple Contact Groups
Discussion in 'Mobile Phones Forum' started by scrapbook, Jan 6, 2012.
Tags:
  1. scrapbook
    scrapbook
    Jan 12, 2002
    7,435
    +553
    Is there a way to set up your phone so that you can view say either business contacts or friend contacts separately?
    The only way i seem to be able to do it is setting up contact widgets for each.
    If I go into my App drawer and select contacts all contacts show up in one long list.
  2. archie2000
    archie2000
    Dec 9, 2006
    565
    46
    Bromborough, Wirral
    +199
    If you select a contact from your list, and then go into the menu you can choose to edit the contact, and you should be able to assign a group to the contact from there
