Multiple Component / DVI output?
Discussion in 'Nintendo Forums' started by Peabo, Oct 23, 2004.
  1. Peabo
    Peabo
    Are there any cables available that will connect to multiple consoles (Xbox, PS2 and Gamecube at the very least!) and output to a single Component or DVI?
    The reason I ask is becasue I have only one Component and one DVI input in my television and having to fumble around unplugging cables is not much fun! I know there is already an Xbox & PS 2 dual component cable. There is also a cable that connects to 8 different consoles and outputs to an RGB Scart - I really would like the higher quality of DVI or Component though.
    Thanks in advance!
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  3. Peabo
    Peabo
    Thanks, that looks pretty useful! Is component much better than RGB Scart?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    yeah if you have a plasma on a CRT less noticable
  5. Peabo
    Peabo
    I do have a plasma. I just got it on Friday - component seems to look amazing compared to anything else.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    I reckon you should get a component switcher then i havent used one of those i linked to but cant see why it would cause a major issue mate,
