belgiansound
Hi All,
I registered especially on this forum as I noticed there is a big BK Monolith following here.
I bought 4 Eminence LAB12C subwoofers and I'm planning on building some DIY clones of the BK Monolith Plus, or an 'improvement' over the original design. I would like to get the maximum out of the drivers, while using a limit of 100L per driver.
I have a stereo setup, 2 Canton CT2000 main speakers. Would like to add subwoofers to improve the bottom end and release some strain from my main speakers.
First off, I would like to know if anybody has some experience with multiple BK monolith subwoofers in their system? Do they reach the claimed 20Hz and below in room? My room is 9x11m in a L shape, so quite long walls (as this affects room gain).
Secondly, i would like to know if anybody 'improved' the design? Looking at the design it seems like they use only 1 shortish port, I would expect some chuffing at higher volumes. Does anyone know the tuning frequency of the box used by the BK Monolith?
thanks in advance!
thanks in advance!
