multiple amplifiers
Discussion in 'AV Receivers & Amplifiers' started by jamesmmm, Feb 23, 2005.
  1. jamesmmm
    jamesmmm
    Mar 17, 2004
    56
    hi,
    is it possible to connect two separate amplifiers each with their own speakers to one cd player. i plan to use an adaptor to attach two sets of interconnects from the cd player? would there be any issues with the output level of the cd player? are there any other issues i should consider? i plan to be able to have both amplifiers turned on simultaneously.
    thanks
    james
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    No problem there, having both amplifiers on simultaneously could produce some interesting sonic effects though. :)
