Multimedia Remote recomendations
Discussion in 'Home Cinema Control & Remote Controls' started by rvfgod, Jan 10, 2012.
  1. rvfgod
    rvfgod
    Dec 20, 2010
    7
    Swindon
    Hello All,
    I am looking at purchasing a multimedia remote control.
    My local Richer Sounds dealer has recommended I purchase a Logitech Harmony One+ especially as the new website (MyHarmony.com) eases the setup process.
    This will be my first multimedia remote, and while I am technology savvy, I was just wondering if this was regarded as a good choice.
    I have a Sony 3D TV (KDL42EX723), Sony AV Reciever (STR-DH810), Sony 3D BR Player (BDPS470MR), Virgin TiVo (Cisco
    Set Top Box) and an X Box 360.
    Thanks for reading this!
    TTFN Ricky
  2. logiciel
    logiciel
    Feb 2, 2008
    53,021
    UK
    +5,729
    Hi Ricky.
    The web site, which is not new, does not speed anything up, and it has disadvantages, especially in using a much smaller database of devices.
    That does not matter though as the One+ is identical to the One and can be set up in the normal procedure, which is very easy to use.
    So, get whichever is at the lowest price.
    Alternatively consider the 600, 650, and 700 models: Harmony Remotes.
    HTH - Logi
