Multichannel power amp recommendation
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by kevshed, Nov 10, 2004.
  1. kevshed
    kevshed
    Oct 30, 2002
    1,249
    48
    bournemouth
    +98
    Hi Guys,
    Looking for a 7 Channel Power AMP that can recieve 7 analogue channel inputs from a pc output. Objective is to let PC do all DD/DTS/DVDA decode. Rather than pay for unneccessary processing in a reciever.
    This is a work project, not home, so please no flaming about PCs as sources.
    Any recommendations?
    Thx
    Kev
  2. Keiron
    Keiron
    Feb 22, 2001
    3,321
    Stockport
    +112
    I'm all in favour of using PC as a source - I have all my CDs stored as wav files (but will perhaps convert to Apple Lossless) and connected to an external processor. It is significantly better than any CD system I've ever had, and there are good technicla reasons for this too I believe.
    Anyway, you're likely to open up more choice by going for a 5 channel amd and a stereo amp (you only need power amps of course if you're using the PC as the pre). That's if you really must have 7 channels. That way you could have better quality front left and right if that mattered. Personally, I'd investigate the Rotel range (which is what I use). No nonsense, bombproof, good sound and great value.
  3. kevshed
    kevshed
    Oct 30, 2002
    1,249
    48
    bournemouth
    +98
    was looking at the Rotels, thanks a lot for the post. Will go and investigate :) Thx
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,425
    The Borders
    +3,231
    kevshed
    The Flying Mole Digital amps should be on your hot list - or not so hot in this case; these are seriously efficient amplifiers that take up minimal space and draw little or no current when idle (or running at full tilt).
    You can look at the 'stand alone' alone DAD-M100Pro modules or the 'hot swappable' cascade series; if one channel dies you simple swap it out for a good one!!!
    See http://www.flyingmole.co.jp/en/products/dadm100pro/index.html
    and
    http://www.flyingmole.co.jp/en/products/dpam1616/index.html
    Any questions please shout.
    Joe
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,425
    The Borders
    +3,231
  6. AndoverRed
    AndoverRed
    Sep 24, 2004
    252
    Andover
    +5
    Joe,
    How much is the cascade series?
    Mark
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,425
    The Borders
    +3,231
    Andover Red
    The Flying Mole Cascade Series have the following UK SRP's - we can work out an AV Forum's Special price if your interested.
    DPA-M16 19" Chassis - £896.30
    DPA-M16u2 160/4ohm 2Ch module - £640.21
    DPA-M30u1 300/4ohm single Ch module - £640.21
    DPA-1U Blank module panel - £17.07
    You can populate the rack with up to 8 x 2Ch modules.
    Best regards
    Joe
  8. AndoverRed
    AndoverRed
    Sep 24, 2004
    252
    Andover
    +5
    Joe,
    I assume these are same beast as the standalone moles but in a modular chassis?
    I have tried a couple of standalone moles and quite liked the sound.
    Mindyou, it will set you back £1,500 to get going (power the fronts)!
    Mark
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,425
    The Borders
    +3,231
    AndoverRed
    Yes the Flying Mole DAD-M100 and Cascade Series share the same circuitry so yes intrinsically they are the same product with the same 'sound' - this article from Widescreen Review is well worth a read.
    See http://www.flyingmole.co.jp/en/whats_new/040916_03_1.html
    Best regards
    Joe
  10. jfinnie
    jfinnie
    Oct 1, 2004
    4,220
    Norwich
    +1,682
    Hrmmmm... certainly not a flame, but you should bear in mind that:
    As far as I know, the only readily available soundcard (including the likes of the Delta 1010s) that has analogue volume control circuitry AFTER the D-A converters is the Terratec Aureon 7.1. (It's integrated into the Wolfson WM8770 codec - I know as I just designed a soundcard based around this!)
    Why is this important?
    If you plug any card that doesn't have an analogue volume control into a power amp directly, and you try to vary the volume down to an acceptable level (assuming you'll end up going for something with upwards of 100 watts per channel) the volume control will be achieved, not using a nice high quality resistor, (analogue tech!) but by throwing bits of data away, purely in the digital domain. This has an awful effect on the audio quality.
    AV amps work by either having a stupidly large 7/8 gang potentiometer, a high quality digitally controlled (but still analogue!) volume control IC such as a Cirrus CS3310 (about $9 a pop last time I asked Cirrus!), or being completely digital.
    Good luck with your project though, sounds fun!
    J.
  11. kevshed
    kevshed
    Oct 30, 2002
    1,249
    48
    bournemouth
    +98
    Good Point.... guess i need to try this first. All plans on hold until i can confirm it will work ! :) Many Thx
