Multi zone remote Electric heating system info needed.
onelife2000
Can anyone recommend good electric wall radiators
I need to replace all the ones in my flat - all 1960's Dimplex ones. They work fine but the control units are dirty and old and I am selling my flat.
Central heating is not really a possibility as it's all solid concrete floor and cavity walls construction and would mean pipes showing or major upheaval.
Underfloor is not possible either - I have very nice solid teak floors.
Also to be honest. We had foam insulation in the walls in november and since then I have hardly had the heating on even in this weather.
Ideally i want RF or Mains wired controlled system. I have found these.
The RF seems simpler but more expensive - The Mains seems to require separate enormous mains filters.
Electric radiators and Electric central heating supplier in Bradford, Leeds & Yorkshire Effective Energy Systems.
Electric Radiator & Radiators, Electric Towel Radiators and Electric Radiant Panel Heaters from Ducasa
INSTALLED HEATING
just as added info this is for a 2 bed flat - 2 large 1.5kw - 1 1kw and 2-750w currently and they are fine.
Ideally not much more than £1k
Many thanks in advance
