Multi zone -Multi input set up for pub
Discussion in 'AV Receivers & Amplifiers' started by Cubittz, Mar 6, 2013.
  1. Cubittz
    Cubittz
    Mar 6, 2013
    2
    Currently have a SoundLeisure jukebox in my pub that plays music to 3 separate zones with a central volume control and track reject button. Additionally there is a mode to play audio from the Sky box to the same 3 zones (during football etc).
    I've been pulling my hair out trying to figure out a system that will do this, with the additional ability to continue to play music in 2 of the zones whilst the other plays audio from the Sky box.
    Am planning to get rid of jukebox totally and have Spotify running for customers....but will still need to switch audio to any one of the zones between music and tv.
    The current speakers are the cheap empty box types that typically come with pub jukeboxes. Hoping to continue to use these, though may not be possible.
    Any advice on where to start with this would be greatly appreciated. Hoping to spend on the right side of £1, 000 on new av receivers/speaker selectors etc.
  2. limegreenzx
    limegreenzx
    Feb 9, 2006
    2,018
    +337
    Have a look at the Sonos connect amp. Supports multizone, Spotify and has a line in connection for Sky input.
  3. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,437
    Teac do a stereo multizone amp (980 I believe is the model number) but I think that is only 2 zone.
  4. Cubittz
    Cubittz
    Mar 6, 2013
    2
    Like the idea of Sonos, especially as it is so easy to set up and scale up if needed. Not confident the speakers we already have would be usable with it so would be a reasonable initial cost to get additional speakers or zone players from Sonos.
    Had hoped to somehow replicate the SoundLeisue jukebox set up, which is afterall just a glorified motherboard with specialist cards plugged in. Starting to look like this is harder than I imagined. Will look on eBay for reasonably priced Sonos components, though still hanker after a pc driven solution with a speaker selector....
    Thanks for your thoughts
