Multi Wireless Headphones
thecount
It looks liek the Sennheiser RS65 are still the best buy fgr Wireless headphones - is that still the case?
Also is there a cheaper brand which are almost as good? I wasn't planning on spending that much - I only realy want to use them when I'm on my treadmill.
An if I purchased two, would they conflict with each other?
B
bobbypunk
Rs45 for £80 but don't enclose the ear but are still fairly good.
They do have more than one channel but It's really aimed at giving a clearer signal if one goes bad but may allow two to work seperately.
They are designed to run two headsets from one base unit though and offer a second headset option (HDR45/65/85)
although you'd be listening to the same thing through both headsets!
BAD Dave
Check out the new Sennheiser RS 110 & RS 120 wireless models which are starting to appear at online retailers. Good reviews!
