richjthorpe
Established Member
Hi all,
I've got a Sharp LCD with a DVI-I input to it. First of all I'm going to get a 5m DVI-I to DVI-I cable with DVI-I to VGA adapter plugged on the end so I can run a laptop to the TV.
I'm going to feed the DVI cable under the floor boards and later in time might link the DVI cable to a DVI or HDMI source. The only problem being, these sources (DVD/Blu Ray/HD-DVD player or Digital AV amp) will probably have a DVI-D connecter making it physically impossible to connect a DVI-I cable (a la Denon x910 range).
Is there an adaptor that converts a DVI-I plug into a DVI-D plug or HDMI plug ?
Thanks,
Richie.
Thanks,
Richie.
