Multi Subs?
Discussion in 'AV Receivers & Amplifiers' started by bwstsw, Sep 30, 2003.
  1. bwstsw
    bwstsw
    Hi all,
    I have a entry/mid range Sony amp, with 1 sub out connector, is it poss to connect more subs somehow?
    Cheers :)
  2. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    No problem, just use a Y-connector / adapter cable if your sub doesn't have an output to daisy-chain them.
    (Or buy the new sub with in- and output.)
  3. jameslindsey
    jameslindsey
    May 21, 2003
    410
    +20
    Depends on what you wish to do.
    If you simply want 2 subs outputting the same then using a splitter cable from the same output will be enough.
    I would recommend not using the sub output however. Depending on your front speakers you may like to try setting up the front channels to output to each sub with the crossover output of the sub going to the front speakers. The effectively separates tfilters our the sub bass from your front speakers, reducing cabinet vibrations and allowing for cleanmer treble & midrange, whilst ensuring even bass distribution across the whole of the front (you need to situate the subs next to each front). If you try this out you must remember to switch the sub output off on your amp so that the low frequencies from the soundtrack are re-routed to the front speakers and you dont looses anything.
    Controversial advice I know but worth a try if you already have the subs. This system works well with the Rogers speakers I have, essentially bookshelf speakers that stand on their own passive subs to turn the whole package into floor standers. I'm not sure why but this seems to be a design that is not utilised anymore but I have found it compares favourably to similarly priced setups.
  4. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    I think a digital xover is always better than the analog in the subwoofers, unless you want to use lower cutoff then available on the receiver...
    I use the splitter for my two subs...
  5. bwstsw
    bwstsw
    Are there any good sites you guys know of where you can buy these splitters etc? cheers.
  6. Mogli
    Mogli
    Feb 25, 2003
    764
    43
    +124
  7. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    I use Monster Cable YM2F-H
