Multi-standard converter
Discussion in 'Projectors, Screens & Video Processors' started by Jeff, Nov 18, 2001.
  1. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    I need a box to convert from analogue sources to SDI so that I can feed it through my DScaler SDI card. The problem is the cheap converters aren't cheap and are quite limited. Then I came across the new Kramer FC-4045 which is availale for about £1000.
    http://www.kramerelectronics.com/group4/fc4045pic.html
    Does this look any good? Maybe Richard A can comment, are there any other products at around this price level that I should look at.
    Thanks,
    Jeff
  2. RichardA
    RichardA
    Jeff,
    I have to say it doesn't look bad - I haven't seen one in the flesh, so to speak, but generally Kramer kit is effeciant and cost effective. The only questions I would have on it (and any other box you may look at) are;
    Does it handle poor timebase signals (i.e. VHS)?
    Does it handle Macrovision?
    How good is the composite decoding?
    The only other solution that springs to mind are the Miranda 'pens' as sold by Canford Audio - unfortunatley my catalogue is in the office and I'm not so I can't check pricing but I think they are in the few hundred pound range.
    hope this helps,
    Richard.
  3. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Thanks Richard, I had a look at the Miranda Picolinks which are available in the US for about $650, the only supplier I could find in the UK has them listed at over £700. I would be interested to find out how much Canfords sell them for. At £999 the Kramer looks like a bargain to me, I'm not too worried about composite or macrovision, it will mainly be used for things like Sky Digital (svideo or RGB) or PS2 (svideo or component). I really like the idea of having an any to any standard converter rather than get a box that just converts svideo - SDI or component - SDI. The other route is to go straight SDI - SDI, but at about £1000 for a DVD player and £1500 for Sky its very expensive. I'm hopeing that using a good external AD converter will still be much better than feeding analogue into a PC with a cheap capture card.
    Jeff
