Multi scart problem
Discussion in 'Cables & Switches' started by Boojiboy, May 8, 2005.
  1. Boojiboy
    Boojiboy
    I am trying to connect a Yamaha S520 DVD into a multi scart box. There is also a PS2 connected to it. When the DVD is connected the sound cuts off from the PS2. The scart box is unswitched. It doesn't matter what order I connect them into the box, both work fine when connected independantly. The TV is just a portable with one scart. Hope this is enough info for someone to help. Thanks
