Multi room
Discussion in 'Satellite TV, Sky TV & FreeSat' started by lovemovies, Mar 26, 2006.
  1. lovemovies
    lovemovies
    Mar 3, 2003
    231
    United Kingdom
    +5
    I have Sky multi room for normal Sky digital. If I upgrade one box to Sky HD and choose to locate the redundant one in a third room, will sky sky want more money for Sky in three rooms? I think this is possible as the LNB has four outputs to cover two normal boxes and a Sky HD box.
    Cheers.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    If you want the third box to carry subscription channels then you will need to take out a second £10 multiroom subscription and connect it to the phone line. Apart from that the install should cover the adding of the other two LNB feeds that would be required.
    If you just want the extra box to be for freesat then you will need a £20 smartcard from SKY.
  3. lovemovies
    lovemovies
    Mar 3, 2003
    231
    United Kingdom
    +5
    Thankyou
