Multi room- which AV amp?
Discussion in 'AV Receivers & Amplifiers' started by rudy, Apr 5, 2005.
  1. rudy
    rudy
    Jan 2, 2005
    499
    Need a powerful AV amp for long runs- wired into 3 seperate rooms.
    Want to be able to choose which room to activate.
    Budget from 700 to 1300. Any advice?
  2. Flimber
    Flimber
    Sep 22, 2002
    13,679
    Yorkshire
    +4,476
    Denon AVR-3805 does two extra zones/rooms, IIRC. One can be video+audio and one audio-only.
    Mike.
  3. rudy
    rudy
    Jan 2, 2005
    499
    Thanks Flimber, what is IIRC? Is it in room remote control?
  4. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    IIRC = If I Recall Correctly
  5. rudy
    rudy
    Jan 2, 2005
    499
    ah, very technical(!)
    cheers for that
  6. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    Most amps above the £500 range will give you multi room, usualy the second zone is powered by the amp but the third requires an external amp as you get a phono out for it. They usualy send video too, usualy composite or s-video only though.
  7. rudy
    rudy
    Jan 2, 2005
    499
    Thanx mate,
    that was useful info.
    I am off to superfi today to look at a Pioneer 2014 amp for 500 notes...
