LestatLondon
I have set up (and finally got working) my new home's video distribution system. I got a 4x4 matrix which distributes 1080i (it didnt work for 1080p) video to 4 rooms, from 4 input sources. VERY pleased I got this to work
Sources are located in a room under the stairs
- 1x Sky
- 1x DVD
- 1x MacMini
- 1x (not sure yet, maybe PS3)
And in the four rooms, I got tv's (some plasma, some LCD) with Freesat encoders inbuilt.
When I bought the house, it was wired with one Cat5e cable and one coax cable behind each TV (Wall mounted). The Cat5e is gone (used for video distribution), Co-ax is being used for freesat etc.
RF distribution NOT an option as I have too many breeze block walls between the TV's and the central location for the sources.
Any ideas of what system I should be looking at for co-ax ?
Many Thanks !!!!
- 1x Sky
- 1x DVD
- 1x MacMini
Many Thanks !!!!
