Multi Region?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Treadstone, Dec 23, 2006.
  1. Treadstone
    Treadstone
    Jun 4, 2006
    1,395
    48
    +46
    I've just become the proud owner of a Marantz DV6600, which was sold as Multi Region, but, as I don't yet own any non R2 DVDs, I can't test it. Does anybody out there know if there is any way to tell if it is set to multi region? I understand that it can't be set using the remote.
  2. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,022
    Bristol
    +9,735
    Without trying a disc from another region there is no way to be sure.
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,577
    Edinburgh
    +1,269
    I would try the following procedure which is for the DV7600. It may very well Work for the DV6600
    1. Open tray.
    2. Press Clear, 2, 5, 8, 0, Clear.
    3. The display indicates, “test mode” press down with the cursor until 1215 is
    displayed press 13 then enter.
    4. Display will now show 1213.
    5. Move the cursor up until 1402 is displayed then press 0, 0, enter.
    6. Display will now show 1400.
    7. Power off then on.
  4. John Watts
    John Watts
    Jan 27, 2001
    3,961
    71
    Leeds
    +80
    Hi EdIngley,
    Did you buy the unit private sale or from a shop?
    I can give you lots of advice but i need to know where you bought it from.
    Merry Christmas by the way.
    Regards,
    John.
  5. Treadstone
    Treadstone
    Jun 4, 2006
    1,395
    48
    +46
    I bought it on ebay with an SR4001 receiver. It was claimed to be MR, but at the moment I have no way of telling if it is. Any help would be much appreciated.
  6. Treadstone
    Treadstone
    Jun 4, 2006
    1,395
    48
    +46
    CrustyLoafer. Tried the initial button press, but nothing happened, so I guess it's not the same. Thanks
