Multi region upgrade for HK DVD506?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jason Jackson, Jan 18, 2004.
  1. Jason Jackson
    Jason Jackson
    Hi Anyone point me in the direction or mail me a firmware upgrade for the 506? I have tried the apache upgrade for the DVD25 but it doesn't appear to work for the 506. When I press the clear button on the remote the DVD doesn't switch itself on for example.
  2. Steve Rollings
    Steve Rollings
    If it is the same as the DVD30 then try this (even if it is not).
    1. Put the machine into standby.
    2. Hold down the clear button on the remore for 2-3 seconds only.
    3. Enter 314159 on the remore, then the region(1-0)
    The machine turns itself on and it should work.
    Steve
  3. Jason Jackson
    Jason Jackson
    Nope that doesn't work.
  4. Serpico
    Serpico
    Jun 22, 2002
    339
    Hull
    +7
    · Ensure there is no disc in the tray.
    · Press OSD (On Screen Display) to bring up the screen menu. The first menu is the required one. Any other menu option will fail to allow the code change to take place.
    · Enter the code 314159(region) = (1234560, 0 = All Regions)
    · Screen reverts to background graphics.
    The player will now run the required region code.
  5. Jason Jackson
    Jason Jackson
    That works thanks.
    Don't suppose anyone knows of a firmware upgrade that'll make the player permenantly region free? Seems a pain to have to use the remote code every time on a £250 player.
  6. Jason Jackson
    Jason Jackson
    In answer to my own question that code permenantly changes the player to that region untill such time as you re-enter the code and change the region.
    Many many thanks.
  7. Serpico
    Serpico
    Jun 22, 2002
    339
    Hull
    +7
    Excellent. Can't wait for Friday and my chance to play.
  8. dbelton
    dbelton
    Serpico,
    Will the Region hack allow you to play RCE discs?
  9. Serpico
    Serpico
    Jun 22, 2002
    339
    Hull
    +7
    I believe so. I'm not sure if I have any RCE disks to check.
