MULTI REGION Toshiba SD340E
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jonno65, Feb 6, 2005.
  1. Jonno65
    Jonno65
    I bought a multiregion toshiba 340e from amazon back in sept 2004 and all seemed fine till xmas when i hadn't used it for a while i wanted to watch a r3 film and it wouldnt play it at all or it would be very jumpy.
    I have since noticed that it doesnt like playing some of my r1 discs and even some r2 as well have also tried r3 version of spiderman 2 and i cant even get the menu!!
    Have tried unplugging the power then plugging back in as tosh suggest bet still have pobs
    Any Ideas Anyone???
    Jonno65
  2. SNICK
    SNICK
    Feb 4, 2001
    793
    28
    UK
    +29
    It should still be under warranty - send it back to Amazon for a replacement.
