Multi-region Tosh SD330 & RCE Discs?
Discussion in 'Blu-ray & DVD Players & Recorders' started by digitaldave, Jul 9, 2003.
  1. digitaldave
    digitaldave
    Jan 7, 2003
    259
    St Evenage
    +12
    I've just got a Toshiba SD330E multi-region from Amazon - does anyone know if this will play RCE discs OK? Tied a search, but couldn't see anything :(.
    Also, is there a way of finding out which R1 discs are RCE?
    Cheers,
    Dave.
  2. one_jedi
    one_jedi
    Haven't got one myslef but people on the DVD forums have confirmed that the Amazon Toshiba 330 DOES play RCE! So you should be happy.
    When it comes to RCE virtually all of Columbiar/Tristar dvd releases are RCE. To find out go to www.playusa.com (new Region 1 site from play) and just search for the dvd's you want and it tells you if it's RCE or not.
    Hope that answer helps!
  3. digitaldave
    digitaldave
    Jan 7, 2003
    259
    St Evenage
    +12
    one_jedi,
    Thanks for the reply :). That's what I was hoping to hear :).
    Cheers,
    Dave.
