Multi Region PS2
Discussion in 'Playstation Forums' started by themmings, Jan 13, 2003.
  1. themmings
    themmings
    Nov 21, 2002
    382
    Northampton
    +4
    Hi, quick question:
    Can the PS2 be made into a multi region DVD player with somekind of software hack?
    Tim:)
  2. Dunedin397
    Dunedin397
    No, I'm afraid not. To play any region DVDs, you need to either get your machine chipped, or get the DVD Region X from Datel or the Region Free disc from Blaze.
    You put the disc in the PS2 & then you're prompted for the region you require. You then load the DVD & off you go.
    The DVD Region X and the Region Free discs will also give you RGB SCART playback in full colour.
    Dunedin397
  3. themmings
    themmings
    Nov 21, 2002
    382
    Northampton
    +4
    Excellent - do you know how much the Region X or Region Free discs cost?
    Tim:D
  4. Dunedin397
    Dunedin397
    £10 to £15 or so. RGB SCART cables can be had from £5 to £30 for the offical Sony cable.
    Dunedin397
  5. themmings
    themmings
    Nov 21, 2002
    382
    Northampton
    +4
    Excellent stuff..:D
    And the last question:blush: where can I get the discs from?
    Tim:)
  6. FluffyHunter
    FluffyHunter
    FYI, the Blaze Region Free disc from Play.com, £6.99 !! (inc. delivery)
    Matt
  7. themmings
    themmings
    Nov 21, 2002
    382
    Northampton
    +4
    :D :D :D :D :D
    Cheers all.
    Tim
  8. currysauce
    currysauce
    You can also use the Action Replay CD. Better than Region X as you have the cheat facility if required.
