Multi-region progressive scan DVD ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by leedavies, Jul 18, 2004.
  1. leedavies
    leedavies
    Jul 8, 2004
    192
    Cambridge
    +7
    I'm about to invest in my first projector (Infocus 5700) and am looking to replace my R2 Sony DVD player with a multi-region player that outputs progressive scan.
    Any models to recommend or warn against?
    Ta in advance,
    Lee
  2. Ged
    Ged
    Apr 29, 2002
    946
    +24
    I would suggest one of Pioneer's players as they can play almost any format and now quite cheeply. I moved away from Sony due to it's issues with -R and now have the 565 and 757 Pioneer players, not sure of +RW playback though.
    Check out the speck and buy which suits your requirements, you may need to look at the digital video out players if the projector supports it.
