Multi-Region On Panasonic DMR E85H
Discussion in 'Blu-ray & DVD Players & Recorders' started by Scarlet, Jun 4, 2004.
  1. Scarlet
    Scarlet
    Feb 3, 2004
    16
    3
    Fifth dimension...
    +4
    Hi all,
    Just purchased one of the new Panny E85H recorders which came modified for multi region. Everytime I try and playback NTSC a 'wrong TV system' appears on the screen. If I switch via the setup menu to NTSC then everything works fine.
    However...,
    Does anyone know how I can record a PAL signal from SKY on the hardrive whilst watching a US Region 1 disc? it seems the setup option for TV signal change becomes frozen out while the harddrive is in operation.
    Gotta go to work now (no internet) but would appreciate any answers to this dilemma.
    Cheers,
    Martin
    Ps. It's a great little machine otherwise
  2. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    You cant.
    If watching in ntsc you can only record from an ntsc source and vice versa for pal. I presume the machine will happily work in either mode but not in mixed due to software issues.
  3. Scarlet
    Scarlet
    Feb 3, 2004
    16
    3
    Fifth dimension...
    +4
    Cheers for this Ken,
    Oh well, the goods do what they say on the box, so I guess I cant grumble.
    Thanks again,
    Martin
