Multi-region on a DVD-Recorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by GARYFORUMS, Jul 5, 2005.
  1. GARYFORUMS
    GARYFORUMS
    Just thinking - shock . . .
    multi-region on a dvd-recorder with hd
    would this only allow the normal playback capabilities of the dvd
    but NOT any clever copy dvd to hd type functions due
    to the PAL/NTSC prob
    thinking its of less use on a recorder than a straight dvd-player
    hope this makes some sense
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Multii-region only means it will not reject playing a disc due to the region code, it doesn't give you anything special with PAL and NTSC.
    Virtually all PAL DVD players will play a NTSC disc. Some DVD recorders allow you to record NTSC input (as NTSC), no recorders convert from NTSC to PAL.
    Mark
  3. GARYFORUMS
    GARYFORUMS
    point taken
    i'm thinking if your also going to have a sep dvd-player to do divx etc. - get that multi-region but not bother with the dvd/hd recorder ?
    any comments
  4. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Agree, unless you want to use the DVD-recorder as a player for other region discs, you don't need it to be multi-region. You can't copy a copyrighted DVD anyway, and most region coded DVDs are also copyrighted, with CSS and Macrovision protection etc.
    Mark
  5. GARYFORUMS
    GARYFORUMS
    good comment re: copyright , for e.g. read the pioneer 530 can copy a dvd to the hd but i guess as u say , non copyright only (or use a backup)
    be easier to have a seperate one for the non avergae stuff
