multi region hack limit dvd9900se
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by saint_simon, Jan 17, 2003.
  1. saint_simon
    saint_simon
    can you help me just bought limit dvdv9900 from r/s and seem troulble apply the muliti region patch. r/s gave me a sheet saying the following
    open door
    press 8888
    press setup
    press next button (where is it ?)
    (a setting interface will appear on screen)
    select zone
    select free zone
    Please help me
    Dose not seem to work
  2. dejongj
    dejongj
    Simon,
    Sounds like you have been given the wrong sheet!!! But then again there is a Limit 9900 and a 9900SE. You have got the 9900SE which has the progressive outputs correct?
    If so then the hack is.
    M/R Hack:
    Open disc tray.
    Press following keys on remote:
    10+,5,3,6,7,5,1
    then
    9
    For VCD then press 8.
    40d0 will appear 'on screen'.
    press 8 again.
    41D1 will appear.
    Player is now MR & will play VCD.
    Please note that you could have easily found this hack on the forum. But hey I am a nice guy :D
    Jean-Paul
  3. Lynchpin
    Lynchpin
    I got one of these players delivered today and without a sheet. I tried the codes given but i get different answers from the player, it does then play R1 and R2, tested but when powered off it resets itself. :(
    Any ideas?
    K.
  4. dejongj
    dejongj
    If it doesn't work then please check back with Richer Sounds....Maybe there are some different batches...
    JP
  5. Demonshead
    Demonshead
    Can the Macro be removed by a hack?
    D:devil:
  6. dejongj
    dejongj
    I haven't heard of a hack for that. Then again I don't have equipment that is sensitive to Macrovision so I have not way of testing it.
    What do you want to use that is Macrovision sensitive?
