Multi-region hack for Jamo DVR 50
Discussion in 'Home Cinema Buying & Building' started by filfil, Dec 18, 2003.
  1. filfil
    filfil
    Does anyone know the multi-region hack for the Jamo DVR 50? I am sure I have seen it somewhere but can no longer locate it?
  2. Rampage
    Rampage
    Dec 17, 2003
    290
    +7
    Not entirely sure, but I think it's something like this:
    Press open (load)
    press info,2,7,6
    choose region and then press info to close it.
    It's something like that, doesn't work on all Jamo's tho :(
    Had no luck on mine, going to ring them later I think.
  3. honeydew
    honeydew
    Nov 10, 2003
    131
    19
  4. ching
    ching
    Jeez, you're brave! I'm surprised that this patch hangs around after the 2.7.6 firmware is installed over the top of it. Have you tried changing regions more than five times to check that the region change limit is overridden?
  5. honeydew
    honeydew
    Nov 10, 2003
    131
    19
    No I havent but I have just set the region to 'all' and I should not get asked....
