Multi region hack for a Panasonic DMR-E55?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Budgie, May 27, 2004.
  1. Budgie
    Budgie
    Just taken delivery of a DMR-E55 DVD Recorder, but just realised I dont know if it can be hacked for multi region.... can anyone help please?... I saw mention of a hack database, but cant find it :rolleyes:
  2. macdaddy
    macdaddy
    Apr 13, 2004
    298
    London
    +26
    Apparently there is no software hack for the E55 but I did see somewhere that you can "rent" a remote from somewhere that zaps the box and makes it multi-region. I believe it's about twenty quid.
    Trouble is I can't remember where I saw it (on the net somewhere)
  3. anuvid
    anuvid
    I haven't used a service like this before but I found a link after doing a Google to http://www.panasonic-remote-hack.co.uk/
    Sounds straightforward and it's a 'use once' remote. As I said, never used it, but thought I'd provide the link.
  4. cpeterka
    cpeterka
    I found this elsewhere... via google..
    It should work for a similar model, the DMR-E55
    DMR E-30
    Multi-Region:
    Turn On player with no disc inserted
    While pressing Shift on the remote press Setup
    Press Enter twice
    Move the cursor to Other
    Enter the appropriate four-digit region setting, beginning with 000
    Press Enter
    Press Return twice
    Switch unit Off for at least 3 seconds
  5. lochindaal
    lochindaal
    Nov 21, 2003
    138
    has anyone tried this to see if it works on the E55
  6. Budgie
    Budgie
    I tried to try it (!!) but unfortunately the remote control does not have a shift key.... so we fell at the first hurdle there!!
  7. tonycommander
    tonycommander
    Nov 1, 2004
    2,062
    Malvern
    +154
