  2. Notice: AVForums will be offline at 10pm for no longer than 30 minutes for scheduled maintenance. Apologies for any inconvenience this causes.
Multi region hack for 963sa
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by mccune, Feb 4, 2003.
  1. mccune
    mccune
    can someone point me in the right direction for a mr hack for my new philips 963sa. Many thanks....
  2. kelvin
    kelvin
    Apr 22, 2002
    1,544
    Down South... (Bournemouth)
    +45
    Hacks for both MR and Pal-PS can be found here.
    Found this site by doing a search on Google so I'm not sure if it's been used by any other individuals on the forum, or indeed if it works at all, but I'm sure somebody else will chip in with any other methods soon enough... :)
    Hope this helps...
    Kelvin :D
  3. adieacc
    adieacc
    Feb 2, 2002
    128
    16
    South Wales
    This is most probably a stupid question, as i've just bought a pronto and cant get to grips with it, but what is the RC6 command??
    Cheers in advance
    Adrian
  4. Mark P
    Mark P
    R6 Command sets up the dashes on the dvd player for you to input the multi region hack.
    see below:
    How to Enter RC6 command via Pronto
    [For multi-region using a OneForAll (URC7560), to generate the RC6 code:
    2.1. The remote should be set up to control the DVD (setup code 0539).
    2.2. Press the DVD button.
    2.3. Press the Magic button.
    2.4. Press 085.]
    2.5. The display should read '----'.
    2.6. Enter the following with the NORMAL Philips remote:
    [On newer models, there appears to be 11 spaces in which to enter a code].
    222 222 005 255
    The player should now be able to output pal progressive scan + be region-free.
