Multi Region Hack for 868
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Trashman, Dec 26, 2003.
  1. Trashman
    Trashman
    Got my new baby thePioneer 868 AVi on Xmas eve to go with the Pioneer 43, it is bloody fantastic!
    Family geting slightly bored now on Boxing day as I continually demonstarte all the features as friends and relatives drop in.
    One slight problem is that it only plays region 2, not multi as promised by my dealer. I understand I need a progamable remote to store a code in which will free up all regions. Can anyone tell me what the code is, what remote I should buy and is there any other way I might access region 1 disks?
    Many thanks and a very happy new year to you all.
    Jeremy
  2. Bails
    Bails
    Oct 15, 2003
    203
    +3
    This question was posed in another forum (www.avsforum.com) and this was the reply (I have no idea how accurate it is, or even what it means!):
    Yes, region free hack is available.
    I successfully use region free hack code on R2 player version - 668 and 868
    refer infos on link
    http://www.dvdrhelp.com/dvdhacks.ph...yer=Pioneer+454
    Proper code for PalmPC OmniRemote is start (call alternate, original not work ok)
    ---------- hack code for pioneer since 530 to actual model .... ------------
    0000 0069 0042 0000 0154 00AA 001E .................................. find in upper link
    jakub vanek
    www.dvdbase.cz
  3. togad
    togad
    Sep 14, 2002
    291
    +3
  4. togad
    togad
    Sep 14, 2002
    291
    +3
    And to answer Brogan's question on the original thread (sorry I didn't see it - but I guess you can understand why!!), I simply pasted that IR code onto a button on my iPronto.
    I'm not an expert on remotes, but any remote that allows you to actually code the IR command should suffice.
  5. Ultra2man
    Ultra2man
    Dec 19, 2003
    978
    43
    Biggleswade, Bedfordshire
    +164
    Just a thought,
    If your dealer promised you that it should be multi region then shouldn't you be getting straight back on to your dealer?
    I would.
    By the way my one should be turning up on monday and will be multi region as set up by my dealer. No extra charge for this.
  6. Trashman
    Trashman
    Thanks for everyones input I will try on Sunday and post back my results.
  7. Tony Fisher
    Tony Fisher
    Dec 28, 2003
    20
    3
    Hampshire
    Thanks togad,
    Tried your code over the holidays and it appears too work fine with my 868 as well. Just cut and paste to a button on the Pronto.
    It did take two attempts though before the player switched itself off, after which it played region one as well as region two discs.
  8. Trashman
    Trashman
    Thanks for all the help everyone, it is appreciated. Which is the best remote to get or should I just use my palm with some freeware?:clap:
  9. Adam M
    Adam M
    Oct 18, 2001
    724
    London
    +19
    Is there a way of programming the remote that comes with the ax10i to do this?
    it is a learning remote.
    also, once used with the 868, is it region free forever more?
  10. togad
    togad
    Sep 14, 2002
    291
    +3
    Adam - it's a one-time job as far as I'm aware. I don't have and Ax10i, so can't comment on its remote I'm afraid.
    Trashman - unless you're in the market for a new remote, simply use your Palm!
  11. Adam M
    Adam M
    Oct 18, 2001
    724
    London
    +19
    will a palm just do it straight out? do you need special software on the palm in order to get it to output remote codes?
  12. togad
    togad
    Sep 14, 2002
    291
    +3
    I don't have a Palm, but I think there's a program called Omni Remote that you need?
  13. Adam M
    Adam M
    Oct 18, 2001
    724
    London
    +19
    thanks, great help.
    868 in with ax10i.
    all I need now is the damn hdmi cable for the hs20 then woooo hooooooo.
  14. Trashman
    Trashman
    Having sorted out the region hack thanks to my good friends on these forums, the next problem to solve is that of the rumoured existence of HDMI cables somewhere in the world. The only people who have seen these folklore items are AV mag journalists and some dealers. Pioneer themselves have no knowledge of these cables and refuse to get drawn into any debate about faith, religion or HDMI cables.
    I presume that someone will in the end send some HDMI cables via the Red Cross to the UK and we will be complacent until the next time the fatal mixture of Japan and UK works its chaos. Maybe with all the members we have on these forums and the potential money we could buy Pioneer and run it with a little more effort placed in product release planning and customer satisfaction.
    Just a New Years thought.
  15. Senninha
    Senninha
    Dec 2, 2003
    135
    Scotland
    +9
    I've also been looking, and if you call Farnell on 08701 200200 they are expecting some in "very soon" - you can pre-order.
  16. Brogan
    Brogan
    Oct 9, 2003
    7,476
    Cary, North Carolina
    +481
    HDMI cables have been available for some time.
    I've had mine for 3 weeks or so.
  17. zoro
    zoro
    Jan 23, 2003
    292
    from where pls?
  18. Brogan
    Brogan
    Oct 9, 2003
    7,476
    +481
    I know of at least 3 places that had stock - LE Concepts, Joe at TMF and Farnell.
  19. zoro
    zoro
    Jan 23, 2003
    292
    web sites addresses?
  20. bigb
    bigb
    Jan 21, 2003
    989
    Central Scotland
    +59
  21. Adam M
    Adam M
    Oct 18, 2001
    724
    London
    +19
    Brogan, I am after a 5 metre cable and these arent so easy to find.
    I ordered mine from the states from a company called gefen. They have been sellign them for a while and say that they anticipated the demand long before anyone else which is why they are one fo the few places who have sold plenty.
    They have them in stock but only in the shorter lengths. I have to wait a few weeks for the 5m cable I have coming.
    Oh well. component will do for now.
  22. Adam M
    Adam M
    Oct 18, 2001
    724
    London
    +19
    on another note.
    I am still struggling to get the software needed for a friends pocket pc in order for him to region free activate my 868.
    Not being compuiter literate, I didn't know there was a difference between a palm and a pocket pc.
    does anyone have a link to suitable downloadable software?
    it is only for the purposes of sending that one signal and can then be deleted, thus I woudl rather not waste money on it.
    thanks in advance.
  23. togad
    togad
    Sep 14, 2002
    291
    +3
    I'm not sure what pocket pc your friend has, but you'll need to check that it can send 'normal' infra red commands.
    Check out http://www.handango.com/PlatformSea...mId=2&txtSearch=remote+control&optionId=1_2_2 for some remote control software - sorry, but you'll have to trawl through the various programs yourself to see if they can accept "cut and paste" commands as I've never used my Ipaq as a remote. (Note that that link will also come up with programs that will control a PC from a pocket pc - not what you want!)
  24. mjones0
    mjones0
    What’s the cheapest thing I can buy to perform the multi-region hack?
    I had a Pronto a while ago but didn’t like it because I couldn’t feel where the buttons were and had to look at it every time I wanted to press something. I know I wouldn’t use a programmable remote control, so I just want something as cheap as possible to do the multi-region hack with. Any suggestions?
  25. rlierop
    rlierop
    Nov 11, 2003
    15
    Thanks for the input you (togad, bails) all have given us on this item.
    I pasted the code into a button of a Pronto and used it on the 868. If the unit does not switch itself of does it than mean there is something wrong or does the 868 needs to be in a special mode (playing, pause, stop or ???)
    Ronald
  26. Tony Fisher
    Tony Fisher
    Dec 28, 2003
    20
    3
    Hampshire
    Ronald,
    When I used my Pronto to deregionalise my 868, it did not work first time either. I then pushed the button twice on the Pronto (with the player on and no disc) and it turned itself off. When switched back on, hey Pronto region free 868. (Pun intended)
    Tony
  27. Adam M
    Adam M
    Oct 18, 2001
    724
    London
    +19
    anyone near finchley (n3) who wants to come round with a correctly loaded up pronto?
  28. Adam M
    Adam M
    Oct 18, 2001
    724
    London
    +19
    No takers?
    oh well,
    5m HDMI cable arrived.
    Will let you guys know what the results are with the HS20.
  29. zoro
    zoro
    Jan 23, 2003
    292
    how much?
  30. Digger
    Digger
    Dec 31, 2003
    4,204
    World Wide Supermarket
    +206
    Has anyone successfully used a Marantz RC5000 to carry out the region fix?
    cheers
    Dave
