multi region hack 4 panasonic ht900
Discussion in 'Home Cinema Buying & Building' started by daviedee, Nov 17, 2003.
  1. daviedee
    daviedee
    does any one know how to turn this into a multi region player??
  2. blackbull
    blackbull
    I have never found a multi region hack for Panasonic machines hence my purchase of a muliti region SCHT900 to replace a region 2 SCHT70. None the less good luck, if you find one let us know.
  3. daviedee
    daviedee
    i called techtronics to see if they would give me an insight as wot to do, all they told me was that they change software in the eprom, so if i want it done it will cost 80 quid.....
  4. blackbull
    blackbull
    I thought that might be the case...oh well, they do a good job mines is from Techtronics no complaints (touch wood.)
  5. alfablue
    alfablue
    Aug 16, 2002
    287
    19
  6. 127pjsny
    127pjsny
    I hope you have better luck with your Panasonic than I did. My Panasonic SC-HT80 has stoped reading DVD's.
