Multi region for Panasonic A160 (Hack?)
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by BigAl, Jan 23, 2001.
  1. BigAl
    BigAl
    Does anyone out there know of a region 1 or multi region hack for a Panasonic A160 DVD player? If anyone has any hacks or advice I would be most greatful.
  2. General Skanky
    General Skanky
    Jul 28, 2000
    4,253
    71
    Colchester
    +44
    If I remember correctly, it is an IC mod.
    Easy soldering in of the mod. £25 if you can do it yourself.
    The details may still be available at www.techtronics.com
    The mod 'how to' can be downloaded and printed off.
    It should be auto/manual type, therefore defeating any puny RCE problems.
    Douch!!......Wot's da madder, da CIA got you pushing too many penzils?
    Work: www.hughes-tv.co.uk
