Multi Region DVD Recorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by RebeccaE, Mar 29, 2005.
  1. RebeccaE
    RebeccaE
    I'm pretty new to all this and would like some help. I am wanting to buy the above but don't really know where to start, the more I read about it the more confused I get!! :eek:
    Anyway, if some people could recommend some models then I could start from there. I have read that Lite-On is pretty good, but which one??
    I do tape alot from tv so something with pretty big memory would be good, I also tape movies to keep so quality is important as well.
    ps: If recommendations for tv's come with this then all the better
  2. ABP
    ABP
    The new Panasonic recorders seem to be the ones to go for at the moment.
    You can get a DVD only multi-region DMR-ES10 for around £190 Delivered.
    Or you can get a multi-region DMR-EH50 for around £350 Delivered.
    The DMR-EH50 has all of the features of the ES10 but adds a 80GB Hard drive alowing you to record up to 140 Hours of video in the lowest quality.
    EH50 link https://www.discountaudiovision.co.uk/detail.asp/sku=DMREH50
    ES10 link https://www.discountaudiovision.co.uk/detail.asp/sku=DMRES10
    Good hunting
    AB-P
