J
John Langton
Is it possibly to play different region DVD films on the UK PS2. If it is how do I go about this
John
John
You stick in a boot disc into the PS2, the PS2 will ask you to select a region... 1 to 6 if I recall correctly. You make your choice and the tray will eject. Take out the DVD Region X disc and insert your DVD movie, et voila, a non region 2 disc will play in your UK PAL PS2.John Langton said:Thanks Leprekorn how does this program work?
John
