Multi-Region DVD playback in Media Centre
D
DaveP
Is it possible?
I'm running de-css and it allows me to play any region through any normal DVD player (WinDVD, Power DVD etc) but when I try to do it through Media Centre it tells me the DVD is the incorrect region for where I live.
Is there some other software I can install that will get around this problem? Most of my DVDs are R1.
Dave
KraGorn
Established Member
Not sure what you're running when you say 'de-css', AFAIK tools like DVD Region Free and AnyDVD work with MCE, try one on a trial basis.
D
DaveP
Sorry, it's an old version of DVD Region+CSS Free. I forgot the exact name.
I'll try an update
At least it should be possible then
Dave
KraGorn
Established Member
As far as I know it should be, but I don't run MCE myself so can't swear to it. The fact that PDVD is happy but MCE isn't may indicate M$ have implemented yet more damned region checks to defeat the workrounds provided by these utilities.
If so then ripping to hard disk may be your only option.
CES 2023 Round Up: New TV Lineups for 2023 from LG, Samsung, Panasonic, Hisense & TCL
