Multi Region Disc For Panasonic Dvda360?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by KevD, Aug 6, 2005.
  1. KevD
    KevD
    Jun 10, 2005
    10,703
    +1,563
    :hiya:
    I have an old Panasonic DVD A360 Region 2 Machine which has been stored away since I upgraded to the Pioneer 656.
    As far a I remember the A360 was a pretty good machine and I thought I would try to bring it to life again as a second machine but dont want to go the expense of getting it chipped (as most collection R1,3 and can by a good machine now for that cost). I've been reading there is a CD which can set the software to All region and disable Macro as well.
    Does any body know where such a disc can be found? or better does any one have the disc! :lease:
    Any help would be appreciated :thumbsup:
    Kevin
  2. Justin@UH
    Justin@UH
    Feb 21, 2002
    2,192
    63
    Location location location
    +93
    Sorry, there is no CD for this model. Your only options are to either buy a mod chip, rent a special service disc (which cannot be copied!) or have a dealer modify it.... Either way any reputable multiregion specialist should be able to help you out, via a google search or the banner below.
  3. KevD
    KevD
    Jun 10, 2005
    10,703
    +1,563
    :oops:
    Cheers mate, didnt notice the banner below me!
    Checked it out, £20 for my model which isnt so bad (Only places I could find were charging min £55 for mod!). Says a DIY rental which I presume is a disc. So I think I'll get in contact with them.
    Cheers Mate :thumbsup:
    Kevin
