Multi-region conversion for my Phillips dvd+rw
Discussion in 'Blu-ray & DVD Players & Recorders' started by Serpico, Jul 6, 2002.
  1. Serpico
    Serpico
    Jun 22, 2002
    345
    Hull
    +7
    I've searched for a multi-region hack for my new dvd rewriter (phillips dvdr980) and come up empty handed. Can anyone recommend a good place to get a conversion done, if indeed such a thing is available for a dvd recorder.
    Thanks.
  2. tonyc
    tonyc
    Jul 26, 2001
    7
    Newcastle
  3. Serpico
    Serpico
    Jun 22, 2002
    345
    Hull
    +7
    Yeah, I've seen that one, but don't really want to buy another remote to do it, and am worried about all the warnings about frying the dvd.
  4. encaser
    encaser
    Mar 15, 2001
    3,641
    Suffolk/Essex
    +1,250
    Serpico, http://www.homecinemaheaven.com/ should be able to sort you out - they list all R2 philips as a software upgrade at £49 or £79 depending on whether you take it there.
  5. Serpico
    Serpico
    Jun 22, 2002
    345
    Hull
    +7
    Thanks very much.
