multi component on 42pd3000?
Discussion in 'Plasma TVs' started by robbster, Aug 1, 2003.
  1. robbster
    robbster
    Jul 20, 2003
    391
    +13
    I have the 42pd3000 display which im very impressed with but have run into a slight problem. My tosh DVD player goes through the component input on the back of the media box, but I also have an xbox and gamecube which i want to hook up through component. As the hitachi only has one compont input is it possible to run all three through the component connection using a spliter of some sort? Any advice would be appreciated
    Regards
    Rob
  2. Dutch
    Dutch
    Dec 5, 2002
    2,584
    3
    North Yorkshire
    +271
  3. WIRY
    WIRY
  4. robbster
    robbster
    Jul 20, 2003
    391
    +13
    Thanks for the replys Dutch and Wiry
    Would there be any kind of signal loss using these switch boxes? Also what is a AV amp like for using as a switcher?
    Regards
    Rob
  5. WIRY
    WIRY
    I rang the company today and asked about signal lose on the cheeper version, one for 15 qiud, and the guy said there might be in the cheaper one, so he sugested the 35 quid one, (but he would do ) sayng that the 35 quid one dose have gold plated connections and as we all know thats the best condutor.
    thinking about it to my self i surmised that there is no reason you should get any signal lose atall considering the very short distance the signal has to travel anyway, but the goldplated version is the same sape as other av equipment, the other one (cheep one) was more lke the shape that Dutch sugested
    if you can hang on a week i will buy the gold plated version and tell you first hand about signal loss, as i`ve order a HDTV player from the states, and also my dvd player has component, so as you see i need this aswell, If i think there is a major signal lose she will be going back pronto
    as for your queston about using an amp as a switcher, i did`nt know you could use one, as there are only usally 4 sets of phono connections, then again im still abit green to all this av, been at it only two weeks proper.
    I`ll let you kow via this post how i get on if you can wait:)
    if you have another question feel free to ask my limited intelect
    regards
    wiry:)
  6. robbster
    robbster
    Jul 20, 2003
    391
    +13
    Yeah that would be great if you could give us a update on how good the switcher is. I too am new to all this AV business so my knowledge is quite limited also lol. I'm sure there are amps now that have component in and out but there again I could be wrong.
    Thanks again
    Rob
  7. ZeroCool
    ZeroCool
    I was actually looking at purchasing this one below:
    http://www.scancom.ltd.uk/products/avtoolbox/avt-5842mx.htm
    It is £104 but also has a cheaper relative that can't matrix the dual outputs. The main benefit above the lektropacks unit for me would be that it is compatible with a remote control.
    Personally I would be wary about the lektropack version as it is not designed for Component video. And the higher the progressive scan rate the higher the frequency gets that needs to go through it. So there should be a limit to the switcher, especially when it was designed for for composite and audio switching...These comments are purely theoretical of-course, however I think you'll see that cheap or I should say lesser quality cabling can introduce ghosting etc....
    I have heard some good reports on the Audio Authority one, I like the scancom one as my particular requirement involves two screens, one projector and one LCD who both can have a component/PS input. So the matrix option with remote control is the works for me.
    Zero Cool
  8. 3rdeye
    3rdeye
    Why did you buy it from and how much ?
  9. WIRY
    WIRY
    Aufull looking thing tho init, green and ugly, does it not come in black,, i will check the 35 quid one out soon and ifis no use send it back, i think i would rather plug unplug my leads than use the green goddess
    cheers all the same tho
    regards
    wiry:smoke:
  10. ZeroCool
    ZeroCool
    Wiry, rather have green on the switchbox that skimp on the quality of the picture....Anyway it doesn't matter for me as everything is behind closed doors with just a tiny little IR eye comming out..............
    Another disadvantage maybe the lack of digital audio switching on the device. That is definitely where the copperbox products have the edge...but at a price......
    Just shows that different people have different priorities...There is always paint for plastic :smile:
    Cheers,
    Zero Cool
  11. WIRY
    WIRY
    Yeah your right zero i could allways paint it, tell you what i will try the 35 quid one first, and if i see any signal loss i will send it back and the buy the one you posted along with some black paint
    cheers mate
    I will let u know how i get on:)
    best regards
    wiry:smoke:
  12. cwick
    cwick
    Feb 4, 2002
    2,207
    Reading
    +95
    'scuse me if I'm being thick, but aren't you guys comparing apples and oranges ? Looks like the switch box Wiry is talking about is an s-video switcher, while ZeroCool is talking about a component switch box ?
    There'll be a major difference between the two - simply 'cos s-video isn't upto the same quality as component.
    And wasn't Robster after a component switch anyway ?
    Or, like I said, I'm just being thick :blush: I'll blame it on the heat.
    Oh - and while I'm being picky (or thick - did I mention that) - having gold plated connections is in no way an indication of quality components.
    Cheers, Carl.
  13. WIRY
    WIRY
    the old apples and oranges analogy eh, the old classics are the best, well to your questions Gold being the best conductor known to man carries the best signal without degradation, so they say
    (who says) (they)
    as for the s-video switcher, i saw this in the electro catalogue, and surmised that what would a switcher know of what feed it was being fed, these things dont have a brain right, so why the ell not use the ports for component instead arrh
    gave the geezer a bell and he told me it would be A ok
    anyway this can all back fire and leave me looking a total fool, but least i wont be stuck with that
    green box that fell of the ugly tree
    I will post my honest report, as usall as soon as she arrives, the sexing looking one with the nice curves that is
    take it easy guys
    wiry
  14. ZeroCool
    ZeroCool
    cwick as wiry pointed out already but perhaps not as clear as is possible ;-) One can use a standard composite plus audio L+R switcher for component connections in theory. This way there is a potential substantial saving to be had compared to a switch box that is marketed as a component switch box. The s-Video switch box he pointed out has also got the required composite plus audio L+R for each of the four inputs...And it is in black...
    My personal experience with such devices in the past, that it is not too bad with interlaced signals but there is ghosting in the image when run at higher resolutions....
    Lets hope that wiry has got a positive experience so that there is a cheap component switchbox available.
    Wiry can you check it with 720P or higher as well?
    Zero Cool
  15. WIRY
    WIRY
    cool
    Iwill check it with my hdtv player when the little beautiy arrives
    was i making my self unclear again, darn got to stop doing that:)
    peace out dudes
    regards
    wiry:smoke:
  16. WIRY
    WIRY
    Hi guys
    Just got off the phone with keene, and they told me i could use the 35 quid s-video/ component switcher i mentioned above with out losing any signal lose atall, so thats keene and lectropacks told me the same thing, as i was browsing the keene catoluge, i saw antother switcher next to it with a remote control for 50 quid here
    http://www.keene.co.uk/system/keene.htm
    as i was still on the phone with keene i asked about that one and got the same reply no signal lose atall, and its not green :)
    so i ill proberly order one today, not sure which yet, as you dont really need a remote bcoz u have got to get up and put the dvd/video or what ever in anyway
    let you know guys when ether one arrives on monday, i will give it a good testing
    cheers all
    nice threads
    wiry:smoke:
