Multi Channel IR lighting dimmer?
Discussion in 'Home Cinema Buying & Building' started by Alexg, Mar 2, 2005.
  1. Alexg
    Alexg
    Aug 7, 2001
    234
    16
    Hi there,
    I currently have 3 lighting circuits in my HT controlled by 3 switches.
    Wall lights, In-floor lighting, Side lamps.
    I want to include control of these lights by remote controll, however I cant find multi channel IR reciever switches, they are all single channel.
    Does anyone know where I can get multi-channel units from?
    Thanks.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    look at Lutron range Graffic eye springs to mind (may need rewiring and ££££) also the "Varlight" units are available as 2 channel could combine 2 channels?
    Futronix
    Helvar
    and many more make lighting control Helvar DigiDim 4 is a 4 channel dimmer and expanable but will probably need rewiring in that room
  3. Alexg
    Alexg
    Aug 7, 2001
    234
    16
    Thanks Hornydragon,
    Who sell the digidim? I found Helvers site and it looks just what I'm after, there are 3x 3+E T&E cabeles running from each switch to the central point where all the lights come back to so I might be able to use those cables.
    -Alex.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    look at VEDA.co.uk for a local dealer, best bet is to contact VEDA direct (part of Armour PLC) and ask where you can see a demo.
