M
Mr_Lloyd
Hello.
I like the look of Muji's first DVD Player: 'View DVD Player'
I've been able to find this out about the player:
The MUJI DVD Player with Remote [UK Spec] is Region 2,
Dolby Digital with 5.1 Audio Output & Optical Digital
Audio. It also supports 4:3 & 16:9 Screen aspect ratios.
It is DVD, CD, CD-RW, CD-R, JPEG & MP3 Disk compatible.
It also supports multi-angle, multi-language & multi-subtitle
Playback & has Standard Video, S-Video & Scart output.
But I can't find out anywhere if the machine is Multi Region or not?
Does anybody know if it is?
Cheers.
Cheers.
