Muffled dialogue
Discussion in 'Hi-Fi Stereo Systems & Separates' started by darrens, Jun 15, 2005.
  1. darrens
    darrens
    Nov 2, 2003
    97
    I bought myself a rather spiffy audio system but am somewhat troubled by the fact that the dialogue is often difficult to hear. I've got a Pioneer AX3, Mordaunt Short 500 THX and have set it all up as per normal.
    I normally watch films on Sky+ using the digital audio out.
    So, the problem I have is that I often find the dialogue a little bit hard to follow. It isn't garbled or muddled all the time but I would hardly call it clear. The centre speaker is directly below the TV and on the same plane as the two fronts.
    I'm not sure if that is simply because the Sky+ box doesn't produce clear audio or if there's something I'm missing with my set up. It's probably slightly clearer when it's digital soundtrack but it still isn't crystal clear. I actually had to give up watching "8 mile" because I literally couldn't hear a word anybody was saying with the heavy accents and my less than clear audio.
    Now, I'm just wondering if this is something that is just a fact of life (and I need a better source) or if my amp/speakers aren't a good combination or if there could be something wrong with my set up.
  2. Londondecca
    Londondecca
    Dec 21, 2003
    2,100
    +103
    I would get a SPL meter to ensure the volume is evenly matched across all the speakers.
    Have you checked the speaker is working correctly ie damaged drivers
  3. darrens
    darrens
    Nov 2, 2003
    97
    Thanks for the reply.
    I don't have an SPL meter but I have checked all the speakers with the test tones that come with the amp set up and they all seem to be working properly and the volume is evenly matched. Perhaps I should turn up the centre.
  4. andyAV
    andyAV
    How does the system sound with the DVD player ? If that sounds okay it's probably sky. They do seem to really compress the sound to death sometimes. It's possible they are squashing the dynamic range too much and loosing some of the quieter stuff in the process.
    If you put your ear close to the front speakers you'll probably hear a faint sibilant hiss or twitter on Sky+ that won't be around on a DVD or the best Sky+ stuff (like movies 1-3 typically with the DD recordings). Suggests the sound quality is poor enough to upset the prologic processing. I've noticed this on the Pio D2011 and on a Rotel 1068.
    I've found forcing the amp to do PCM stereo can often really help in situations like the ones you're describing - sometimes the centre image is stronger and the sound clearer.
    Andy
  5. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    I use Freeview not Sky but have exactlly the same result as Darrens; esp. noticable on US Movies. In fact gave up and I listen to all TV through stereo! Just use five channels for DVD's which are fine.
    Richard
  6. darrens
    darrens
    Nov 2, 2003
    97
    Andy,Richard thanks for the replies. I'll do a bit of playing around trying a good DVD and then trying different processing for the Sky+ stuff. I'll report back my findings.
  7. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    FWIW I experience the same problem with DVD's, I have tried some of the worst offenders through all sorts of systems and in the end it seems to be the fault of the dialogue on the DVD itself. If Sky gives a worse signal then its no wonder your struggling.
    Im currently using a Denon AVC10SE, 3 matched NEAT petite fronts, pair of Energy rears and an SVS sub connected to a Berhinger FBD. Everything is set up using sine wave test tones and SPL meter.............and guess what??
    still has poor dialogue on most DVDs :rolleyes: Maybe Im just too picky, as I have a really good HiFi, but it does make me wonder if I should really have spent so much money on a system which is reproducing poor software......................pays your money, takes your choice and it looks impressive and sound effects are brilliant, but the dialogue is still poor.
  8. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    It's most likely an acoustics issue, I can't think of any of the hundreds of DVDs I own were the dialogue is poor.
  9. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    Virtually all mine have poor dialogue, its easy to compare if I stick on something like Roger Waters live DVD, the difference is incredible.
    I first noticed it on Jurrassic Park, so I purchased the DTS edition, dialogue is still pretty poor, but the bass parts are a lot better (dinosaur footsteps).
    In terms of an acoustic issue, I shall soon be able to check as Im moving my system into a custom designed room, which is sized to the 'magic' formula (I would love to get my HIFi in there).
  10. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,744
    The Borders
    +3,085
    Darrens
    Try overriding the MCACC calibrated setting for the centre channel - I've often found the combination of SKY/AX3 or 5 results in difficult to follow dialogue - you often have to 'lift' the centre out of the mix.
    Best regards
    Joe
  11. Londondecca
    Londondecca
    Dec 21, 2003
    2,100
    +103
    What is the magic formula, is it anything like the Euclid 'golden ratio'
  12. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    same beasty I think, cant remember the ratios, but by a quirk of fate my new HC room happens to be exactly right. Having spent so long in awkward , all square rooms with acres of bare walls, the almost echo-less sound of the new room is a revelation.
  13. tom_nieto
    tom_nieto
    May 21, 2003
    427
    Brighton
    Turn up the centre. Even if everything is set up impeccably, it could still sound poor to your ears. Basically, do whatever you think sounds best, just have a fiddle and see what happens!
  14. booktrunk
    booktrunk
    Feb 6, 2004
    623
    Leicestershire
    +3
    You could also try to put dynamic range compression on... So there is less fluctuation between the high and the lows.
    I really think you should invest in a sound meter an analogue one is under £30 and it's such a quick and easy way of testing your setup.
  15. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    It is not clear to me how compressing the dynamic range could stop something sounding muffled. Perhaps I am missing something; :) I often do. Common sense would seem to suggest that the sound will be more muffled; perhaps you could explain why it will make dialogue clearer.
    I have never thought of using a sound meter to help solve problems like this; how do these work? what do they tell you about problems like muffled dialogue. Any info gratefully received; thanks
    Richard
  16. booktrunk
    booktrunk
    Feb 6, 2004
    623
    Leicestershire
    +3
    If you compress the range, then there is less difference between the highs and the lows, this way you can turn it up slightly to a level where the dialogue is comfortable and the rest shouldn't blow you away :)
    Sound Meter, check all the different speakers using the test tone, it might be the centre is set to low and it's a lot easier to tell using a meter then just using your ear. Sometimes it's other speakers are to high drowning it out. I once thought I had a problem with the fronts but it turned out the rears were set to high, and that was messing up what I assumed was a front speaker problem.
    Also if it's really dialogue / centre that you seem to be having problems with could you swap it out with one of the other speakers as an experiment to see if it could be the speaker itself that is the problem.
    EDIT: I tend to set all the speaker levels correctly and then turn the centre up +1 notch, don't know why but that's what I do and it seems to work a treat for me.
  17. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    Thanks for quick reply booktrunk. I have tried setting the centre speaker vol high/very high compared with main and rears and it makes things worse.
    I will try compression and see what that does; I know I have my processor set to full range.
    Richard
  18. booktrunk
    booktrunk
    Feb 6, 2004
    623
    Leicestershire
    +3
    What speakers have you got by the way?
  19. darrens
    darrens
    Nov 2, 2003
    97
    Okay, I actually do have dynamic range compression on and it does help. Basically when you have a film that has loud bits (e.g. explosions) and quiet bits (e.g. just dialogue) it makes the quiet bits louder and the loud bits quieter. So, you don't have to continually turn it up to hear the dialogue and then turn it down to avoid the house shaking to bits.
    I have turned up the center (+3db) from where the MCACC calibration set it and that has definitely helped. I still need to play about with the different decoding options (currently on THX) but I did try with plain stereo and direct options and I can't say they helped enormously.
  20. booktrunk
    booktrunk
    Feb 6, 2004
    623
    Leicestershire
    +3
    With regard to sound meter, and people asking why do I need one, well it's amazing how often when you sit in the position where you are actually going to be watching tv/whatever and use it that speakers are not all at the same level. Just becaue the amp says they are at the same it isn't necessarily true :)
    If you sit off centre from the front the chances are the one furthest away from you will be quieter etc... By default most systems i've played with I find the rears in a 6/7.1 system are to high.
    It's things like this that I found the sound meter useful for ironing out. Also the sub. I've now got a BFD with my sub and it's way higher that I would have expect to put it in the system menu on my processor but hey it works :)
  21. Londondecca
    Londondecca
    Dec 21, 2003
    2,100
    +103
    I wonder if there is not something more fundamentally wrong here. Are all the speakers working correctly, do all the drivers move cleanly without any noise. I would also try and substitute the amplifier and DVD player to ensure they are working correctly.
  22. darrens
    darrens
    Nov 2, 2003
    97
    Londondecca, everything seem to work "fine" in terms of the speaker drivers moving cleanly. Although I'm no expert in home cinema I'm quite a hi-fi buff so reckon I would be able to notice if there was a problem (I've got several test cds which all gave no problem and helped me with speaker positioning and so on).
    I haven't tried substituting the amp/dvd player because I don't have another one (and it took me a day to connect it all up in the first place) but I am going to have a play with using different sources (sky vs dvd) and all different decoding options.
    Certainly boosting the center channel +3 has helped but unsure if that has actually solved the problem.
  23. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    hi there, I used to have the same problem with my old system
    Yamaha 630 & Kef 2005.1 speakers.
    The only way I could fix it was by replacing both the center speaker and the amp. If you turn up the center you will loose the front and surround effects which kinda defeats the purpose of surround sound.
    imho once you notice something like this it means you have out grown your current system and you need an upgrade :)
    I now have the Quad L center and a Halo C2/A52 and have no problems.
    CaM
  24. darrens
    darrens
    Nov 2, 2003
    97
    I've been running it "direct" for a week, i.e. only using the fronts and I have to say that I haven't noticed any issues with the dialogue. I just switched it back to normal processing and there does seem to be a real tonal difference which may mean that my centre tweeter has an issue or that I just need to boost the treble on my centre.
    More playing about this weekend.
