Much difference between these 2?
12harry
Similar I guess . . . probably best to take a flash-memory card to yr local store . . . format in camera and try it - then do this with the other camcorder . . . view on a PC (with suitable Media Player) - then compare the Quality, ease of use, weight, cost of second battery (which you will need - I have three and my charger is off-camera). . . .
The real problem is that "not-knowing" your choice may be wrong because you value "features" that you won't need, etc.
Good Luck
