MSI GF4TI4200 8xAGP 128mb ddr
Discussion in 'Desktop & Laptop Computers Forum' started by zypheruk, Apr 8, 2003.
  1. zypheruk
    zypheruk
    Can someone tell me if this card is suited for dvd play back as it is my main pcs graphics card which im thinking of putting into my HTPC Accent case, im not worried about the noise as im thinking of putting a Zalman ZM-80A-HP Video Card HSink on.
    cheers all
  2. Kramer
    Kramer
    It'll work fine but won't have the Radeons' flexibility with higher resolutions via DVI (may not bother you depending on your PJ/plasma).
    The Radeon cards also provide a far better PQ using hardware acceleration IMO (& most others').
    But definitely no problems with it as an introduction to HCPCing.
