MS409 Or XLS200
Discussion in 'Subwoofers' started by Mike Delvaux, Oct 7, 2004.
  1. Mike Delvaux
    Mike Delvaux
    I've narrowed my search down to these two subs,but I'vE a couple of questions.What does the 409 come with,(spm),does it also come with
    a CD to set it up with, and a remote control,also does it have seperate
    outputs for music and LFE.(Whats it like for music)and does any body
    no where you can buy it from other than AVLAND.
    Thanks for your help
    Mike.
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,854
    2
    +3,227
    You have a PM but broadly, the 409 has a setup CD, no remote and is low level input only as studies of 309 owners showed that less than 5% ever used the high level input and brutally we needed the panel space. The business end is a downward firing CPC driver with a 200W digital amp.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    I would guess that the 5% statistic also applies to most other subs apart as well as the 309. I wouldn't worry too much about the lack of a remote either as if you have set the sub up correctly it should be "set and forget" and the remote, which although useful, is either just an additional cost or an excuse for corner cutting elsewhere to keep the overall price down
