MS Premiere Plus
Discussion in 'AV Receivers & Amplifiers' started by pclarke, May 15, 2004.
  1. pclarke
    pclarke
    I would like to purchase these speakers with the CA azur 540R. Is this a good combination....speakers are rated at 4 ohms??
    My other choise is to go for the Sony STR DB790 amp.....any opinions.
    I am a bit new to all this so would really appreciate your help.
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,246
    2
    +3,773
    Would probably be inclined to suggest the Sony as it is much better suited to the 4 ohm Premiere load. They are both pretty sound amps however.
    Ed
