MS Premier Plus - Please advise
Discussion in 'Home Cinema Speakers' started by ReVeReNcE, Jun 23, 2005.
  1. ReVeReNcE
    ReVeReNcE
    Hi, I am considering buying a projector in the near future and want to partner it with a decent surround sound package as well. I am thinking of the Cambridge 640r/540d with the MS premier plus system. I want a sub/sat combination because of the size and would need to wall mount the front speakers.
    My question is would this package be OK for a small/medium size room (currently 3mx4m)? Also, how is the performance of the speakers when used with music? Obviously it won't be as good as a dedicated system and I will be using it about 60/40 for music/films.
    Phew! Thanks :cool:
  2. Dfour
    Dfour
    Jan 19, 2004
    4,088
    71
    Bracknell
    +86
    The MS premieres are very good speakers but like most/all sub/sat packages they are lacking in music as they usually have little or no mid range.
    They are very good though and until you upgrade the front speakers to floorstanders or the like you wouldnt notice to much.
