MS Premier Plus mixed with 902s
Discussion in 'Home Cinema Speakers' started by Goofy, Apr 29, 2005.
  1. Goofy
    Goofy
    Jan 10, 2005
    97
    Leeds
    I am considering using the MS Premier Plus system, but replacing the two front speakers with the larger 902 Avant, to gain a bigger sound - whilst retaining the centre (I like the size) and the surround speakers. Does anyone have any experience, whether this mis-match in size between fronts and centre would cause an imbalance?
    I believe the basic speaker technology in each is the same -except for the different mid-range/bass speakers. Any information would be greatly appreciated.
  2. dazed&confused
    dazed&confused
    Mar 12, 2005
    550
    Kettering, Northants
    +31
    I considered doing this exact same thing before buying a more expensive set of speakers for about the same price by buying second hand.
    The speakers you're considering can be purchased at Richer Sounds. Whatever people say about the, they do have a good policy with regard to refumds, etc. You could buy the complete Avant Premier plus 5.1 set-up plus the 902's, take them all home and try them and then take back either two of the Avant satellites, or the two 902's, or the whole lot for a refund.
  3. GFS AV
    GFS AV
    Jan 28, 2005
    407
    16
    From experience, I would definately change the centre as well. The 905c is a huge step up from the 304. I still use my 905c (see my sig below) and am very happy it. The 902s are good too - I have some for sale now in the classifieds if you're interested :)
    Although the Premiere system is very good for a satellite system, you cant beat a full size setup for sound performance.
  4. Goofy
    Goofy
    Jan 10, 2005
    97
    Leeds
    Thanks for the helpful comments. I will try and get RS to set up some of these speakers in their demonstration room in Leeds - though the idea of taking some extra speakers home and returning the unwanted lot is a useful one - I shall ask them.
