MS Premier-Bananas?
Discussion in 'Home Cinema Speakers' started by mose72, Nov 11, 2004.
  1. mose72
    mose72
    Sep 26, 2004
    2,002
    Brighton/Glasgow
    +490
    Can you put banana plugs into the MS Premier series? ATM there is just a thread, but what looks like a plastic plug on the connector.
    Any thoughts?
    JM
  2. StevieDvd
    StevieDvd
    Dec 27, 2003
    1,378
    Stevenage, Herts
    +151
    You should be able to leve off the small plastic plug with a small screwdriver. The EU says we need protecting as some idiots may insert power connectors in there by mistake!
    Ive removed the plugs from my MS speakers, Marantz AV and I'm still he....................zzzzzzzzzzzzz
  3. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    if you unscrew the nut enough theres also a 4mm hole in the binding post too iirc
