MS High Def Component lead
Discussion in 'Nintendo Forums' started by common, Nov 7, 2003.
  1. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
    Is the Microsoft high def component kit just an xbox component lead or does it do anything 'special'
  2. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Just an xbox component kit although the set of (cheapie) component leads that come with it (to connect from the output box to your input source device) are just standard component leads (cheap ones though)
  3. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
  4. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Yeah, but cannot see how the digital optical sound connection is made on that lead.
  5. bash
    bash
    Nov 10, 2002
    2,945
    London
    +611
    yeah, but if you're a quality freak you might wanna check THIS OUT.
    I'm currently using the offical MS Hi def kit but Im gonna order this as I cant be bothered with the big adapter. Plus I;ve already got the PS2 Ixos component cable and Im gonna get THIS ALSO so no more farting about with swapping.
  6. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    What about DD5.1 though. Where is the optical socket?
  7. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
    no 5.1 for me (sold my HC to fund the 2 channel gear on my sig)
