MS Genies stand question
Discussion in 'Home Cinema Speakers' started by adrianl, Mar 30, 2005.
  1. adrianl
    adrianl
    Love the Genies (driving with Denon 2805) and plan to have fronts on stands, and surround wall mounted.
    It seems to me that although the cable management through body of stand is neat (I like the way a guitar-string type wire is supplied to tug the speaker cable with!), it's a bit of a design flaw that the stand base has to rest on the cable making it slightly unstable. This happens with the QED Micro I'm using which isn't very thick - if cable was thick then stand would be very wobbly!
    Am I missing something obvious? Is it that there would be enough clearance on spikes (I'm using rubber feet - my wife would not be pleased to have spikes on wooden floor!) or should the stand bases have been designed with a notch underneath for the cables?
    Small point but I'm surprised given rest of Genies design is so thoughtful.
    Thanks for any advice,
    Adrian
  2. Pbryanw
    Pbryanw
    Nov 15, 2004
    1,523
    A dystopian Grimsby
    +101
    I too use QED micro with my MS stands but unlike yours I have my stands mounted on spikes (luckily I have carpet underneath) so there seems to be enough clearance underneath. I can see how it would be a problem if you used thicker cable or didn't use spikes though. It does appear to be a design flaw.
    As a possible solution have you tried attaching the spikes to the stands then using something like two pence (or 50 pence if you're particularly generous) coins to mount them on to distribute the weight so the floor doesn't get damaged?
  3. adrianl
    adrianl
    Good suggestion - thanks!
  4. Pbryanw
    Pbryanw
    Nov 15, 2004
    1,523
    A dystopian Grimsby
    +101
  5. adrianl
    adrianl
    Thanks for that. The Ixos ones are still cheap compared with the grief my wife would give mne for using spikes on wood floor!
