MS Genie subwoofer - dual connected?
Discussion in 'Subwoofers' started by AUpperton, Mar 24, 2005.
  1. AUpperton
    AUpperton
    Aug 1, 2002
    177
    on the sofa with controller in hand
    I've recently bought a set of the excellent MS Genies to replace an aging set of Tannoys.
    I've got a Sony STR-DB1070 with dual subwoofer outputs. I'm interested in knowing if there's any benefit in dual connecting the amp to the sub or will a single good quality cable suffice? (obviously to be bought from the forum power buy!!)
    Any thoughts/ideas?
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,183
    2
    +3,638
    It increases the gain a bit and makes the Auto On respond a little faster but otherwise nada.
    EDIT- Do you reckon that you are in the running for longest period between regsitering and posting?- certainly the longest I have ever seen.
  3. AUpperton
    AUpperton
    Aug 1, 2002
    177
    Cheeky!! ;)
    I've not needed to post anything up until now. Either found the answer I was looking for, or somebody else supplied the answer before I did.
    Thanks for the info though. Looks like I'll make do with one cable for now.
    Do I win a prize ??????
    :cool:
